Author Topic: Adding Track Titles When Ripping Easier  (Read 2455 times)
toddoshi
Hi musicbee community
This sounds like a no-brainer, but when entering track titles manually before ripping a CD, is it possible to go from track to track withought having to click on the next track title each time to enter the next track title? This would save a TON of time with my music CD's not recognized and auto-tagged through the system.
Thank you for any help!
captain_paranoia
EAC uses <CR> to advance to the next track, which works nicely. <ESC> is used to leave the editor.
Your query made me try the MB Ripper, which seems to work nicely, but I found the same as you did.
One for the Wishlist, perhaps?
theGleep
This is still an issue in the editor - and is quite annoying as I'm re-ripping my entire CD collection, and have some esoteric discs!
I would be glad to dig through the code and make the fix myself (I looked into the API for a plugin that might be useful, but can't find one).
In the two and a half years since the initial request, there has not been a single person to endorse it.
The code is not open source and therefore not available.
