Author Topic: Key command for saving "edit" tag files  (Read 1239 times)
djdalex
Is there an option for saving the tag editor with a specific key instead of pressing the "save" button on the left side?
Vinyl lover / Vinyl ripper / Vinyl cleaning / Digitizing addict / Audio repair / Audacity lover / Clickrepair.net lover / MusicBee Newbee
ProfessorMarvel
If you press the <Enter> key, your tags will be saved.
You can also assign a hotkey to the Save & Go To Next command.
djdalex
Thanks! That helped me out!  8)
