Author Topic: Change Lyrics Font?  (Read 1501 times)
Poofox
Where can I change the lyrics font?  I've spent an hour combing the preferences and googling, but the option is most definitely not where the wiki shows it to be.
Thanks.
  • MB Version: 3.6.9255 P
right-click on the "Lyrics" header menu (or in the header menu of where you have the lyrics panel)
select "Customise Panel..."
it will bring up the Preferences> Layout (1) panel with the 'lyrics:' settings highlighted for whatever panel you have it set on
