Author Topic: Naming Template  (Read 794 times)
jlewisj1
My naming template is set to <Artist> - <Title> - <Album > - <Year>. It has worked fine for one year. Now instead of renaming using data in tags it just returns the actual template. HELP!
Most likely your template contains some typo for tag names.
OP - You should post a screenshot if you'd like us to help figure out what you're doing wrong.
