The status bar is one of:
1. above the player
<element id="Panel.StatusBarInPanel.Default" bg="112,145,207" fg="81,105,163" />
<element id="Panel.StatusBarControlInPanel.Default" fg="133,178,204"/>
2. below the player but the player is on the bottom pane
<element id="Panel.StatusBarBelowPlayer.Default" bg="106,181,217" fg="51,106,133" bdr="97,168,202" />
<element id="Panel.StatusBarControlBelowPlayer.Default" fg="78,143,175" />
3. below the player but the player is on the top pane
<element id="Panel.StatusBar.Default" bg="112,145,207" fg="81,105,163" bdr="112,145,207" />
<element id="Panel.StatusBarControl.Default" fg="133,178,204" />
For the controls on the status bar there are only 2 color sets available, status bar above player and status bar below.
Are you infact asking for a additional below player color set for the controls (in addition to the one created in v3.2, which wasnt working in any case)
So your saying you created 3 id="Panel.StatusBarControl elements, but only 2 of them work?
