Author Topic: Identifying music files which are not in the library  (Read 650 times)
Axesh
Hi guys,
I'm looking for a way to identify music files from my (dedicated) music directory which are not in the music library.
Because if have a reasonable suspicion, that some files or subdirectorys from my music directory are not included/listed in my music library (formerly iTunes on Windows, now MusicBee).
So, is there a way to identify them easily?, so that I can delete or add them to the library afterwards?
Thanks in advance.
File->Scan Folders For New Files
Add all the folders where your music resides with "Choose Folders"
Make sure "Destination..." is set to "Inbox"
Non-library files that are found will be added to your in your inbox.  From there you can add them to your library or delete them.
The wiki contains a lot of information on basic functions like this, and reading it over will prevent you from having to make new threads for rudimentary questions.
