Hi phred,
- I'm using version 3.1.6590
- No, the directories are only visible under the device node (also tried a different Android device and a USB-flashdrive, all same)
- The path already exists, but when I change the path, or delete it, MB will recognize that and brings up a exclamation mark that says that the directory will be created, but on my Sony Xperia Z3compact, that will not happen... as long as I have the box ticket at "sychronize music" (with 2 active filters).
If I untick these box, and do the sync again, the playlists will be copied, to a new or existing folder.
I'm confused..., I thought that both (music and playlists) are possible. That is the way it should be, or?
Additional: the "..." button didn't worked on both android devices, like on the USB flashdrive where the "find directoy" system-dialog will open up.
