Author Topic: Can't create playlists  (Read 1455 times)
polfor
Hey i've been using musicbee for 3 years now, and last month my HDD failed, so with an all new SSD + HDD pack i reinstalled musicbee.
But now whenever i try to create a playlist i get an error message. Btw MusicBee is on the SSD but my library is in the HDD (way too heavy for my SSD).
Here's the error i get :
MusicBee v3.1.6590.32668 (Win10.0), 21 juin 2018 2:02:
System.IO.DirectoryNotFoundException: Le chemin d’accès spécifié est introuvable. [D:\Musique\MusicBee\Playlists\Liste de lecture.mbp]
   à #=zqg0hrlxkHop9w8o2KeKZOKU=.#=zetvDJYDN1uDM.#=zj6PrpWM=.#=zPeRzHhgiMjf4(#=zqfVqdK_rx3LQj1rVhw== #=zBYd0xYQ=, FileShare #=z36N0cpg=, FileOptions #=zqytymKc=, Boolean #=zPbCwxcRwD3dI)
   à #=zHYxfKvme754v3SJbAqGd0cE=.#=zTB_ltUyU_xjk()
   à #=zHYxfKvme754v3SJbAqGd0cE=.#=zGxc7m9U=(List`1 #=zoQ7k404=)
   à #=zxZ4IE5sI9BaSw2tl_deG6L0=.#=z4vSuABJxSIp6ESNQwA==.#=z$b4FAYM=(#=zHYxfKvme754v3SJbAqGd0cE= #=zjB6YmKc=)
   à #=zHYxfKvme754v3SJbAqGd0cE=..ctor(#=zqfVqdK_rx3LQj1rVhw== #=zBYd0xYQ=, Boolean #=zMp97MfQ=, #=zdfcVf7h0q5yXYYiqTKpy8nk= #=zGvaw7uQ=)
   à #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=z9faxa697Ukc9.#=zS7Kh5tQ=(#=zdfcVf7h0q5yXYYiqTKpy8nk= #=zGvaw7uQ=, String #=zOIphDeo=, List`1 #=zUuBYKlBkTzSU)
   à #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zMBG2GHFl8B7Z(#=zdfcVf7h0q5yXYYiqTKpy8nk= #=zGvaw7uQ=, String #=zOIphDeo=, List`1 #=zUuBYKlBkTzSU, Boolean #=zU_QFJow=)
   à #=zNi5SwjbJAMGXLrmyPHQZYNyVxL3u.#=z9NXCJAc=.#=zSu7LoDs=(ApplicationCommand #=zUcs2ZA0=, Object #=zvvbux2I=, IList`1 #=zoQ7k404=)
   à #=zg_u8zGq8OneWLrok5jATFDs=.OnClick(EventArgs #=zK_CBPjQ=)
   à System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   à System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   à System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   à System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   à System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   à System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   à System.Windows.Forms.Control.WndProc(Message& m)
   à System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   à System.Windows.Forms.ToolStrip.WndProc(Message& m)
   à System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The french bit on top says : The specified directory couldnt be found.
As you can see it seems i'm missing a fille called "Liste de Lecture.mbp" wich stands for playlist. but i can't find it anywhere. Help !
Also if possible i'd like to not have to setup all the app again since i mess around a lot with customization, unless it's the only option left.
Thanks !
Polfor
Be sure that the correct Playlist folder path shows up in the Preferences/Playlists/library playlists path as psychoadept points out in the thread here: https://getmusicbee.com/forum/index.php?topic=25717.0;  hit the "..." browse button next to the path box and point it to where it is now located (on the separate HDD I assume).
As always, updating to the latest MusicBee 3.2x as long as you reinstalled is a good idea:
https://getmusicbee.com/forum/index.php?topic=24754.msg147346#msg147346
Last Edit: June 23, 2018, 08:27:21 PM by sveakul
Also, check this page for info about backing up your customizations: https://musicbee.wikia.com/wiki/Backup_%26_Restore
