Author Topic: Moved Music Library; now MusicBee doesn't see playlists  (Read 1763 times)
Lincoln
Hi.
I just moved my music library to a different location on my SSD. It took me a little bit of fiddling to get Musicbee to find my music, but I succeeded in that.
But I can't get it to see my playlists in the new location. The playlists are there. I can see them in File Explorer. But they don't show up in Musicbee.
Did you try File->Library->Relink Music File Paths?
First be sure that you have Playlists checked in Preferences->Layout(1)->left sidebar->show navigation tabs->playlists if you're not seeing anything at all, because the playlist names should still show up if they're actually in the Library/Playlists folder.
Last Edit: June 21, 2018, 03:32:01 AM by sveakul
Make sure your playlist folder in Library Preferences is pointed to the right directory, too.
