Author Topic: Missing fields in Search and Replace funtion  (Read 1657 times)
Oliver One
Hello,
In the "Search and Replace" function. all fields are not presents. I want for example searching (and replacing) in Original Year and it's not in the list.
Tybot
I believe "Lyrics" is also absent, not sure why this is. IIRC, "Original Year" is a fairly new default tag so that might be the reason in your case.
What version of musicbee are you running? If it's not 3.2, try getting the new release candidate from the first forum board.
Oliver One
Question is for me? I have a last 3.2.6738.34774. All fields are presents in personalized search but not in search and replace…
Oliver One
And there is another issue (a bug even) in this function, I use five Custom's Fields and just two appears in the list! ;)
Oliver One
Important precision, fields who disappears in the list are those with other type than "String". Example, Custom field with the type "String" disappears if I change the type to "Number".
Tybot
I don't believe you're suppose to change that setting.
I have custom tags whose values are numbers only and I've never changed that setting. If it's visible in the "Search and Replace" function as "string", why would you even need to change it?
You can absolutely change field types for custom and virtual tags, that's intentional.  But looks like Steven's solved it, in any case!
Oliver One
Wonderful! Now I access to all fields I want. Thanks Steven.
