Hello there,
if MB is configured to run an embedded visualizer, it isn't possible anymore to run an additional one outside of MB in a separate window - like milkdrop.
Now everyone will start to ask: why this should be possible? Does it make sense?
Well, let me explain why it could be a great feature if MB is able to run 2 visualizers in parallel.
Currently I use a Visualizer called "
Classic Spectrum Analyzer" embedded in the MB GUI - located in the bottom:
More infos about the "Classic Spectrum Analyzer" can be found here:
https://getmusicbee.com/forum/index.php?topic=23345.0Currently it's still impossible to run a "real" graphic visualizer like Milkdrop in parallel to an GUI embedded one.
If a GUI embedded visializer (e.g. "Classic Spectrum Analyzer") is running all the time, but an full-screen visualizer should become startet, the MB settings currently must be changed laboriously each time, when starting end closing the full-screen visualizer.
This is frustrating a lot
So, it would be
VERY WONDERFUL if there where an possibility to run an external visualizer plug-in
simultaneously and in addition to an GUI embedded one.
Thanks for Your attention and support.
Greetings
