Author Topic: program won't run all of a sudden  (Read 845 times)
JimFlasch76
While I was trying to get MusicBee running with my preferred font (Noto Sans) in use after it stopped recognizing it following an update to another program, MusicBee stopped working altogether and gave the following error:
MusicBee v3.1.6590.32668 (Win10.0), 31 May 2018 20:27:
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zoNiiRc2vr4Or.#=z_S_W0bfQn$qUajEc1Q==.#=zw_gBJb3YF2YB()
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zoNiiRc2vr4Or.#=z_S_W0bfQn$qUajEc1Q==.#=z2k5HbRs=(Boolean #=zZEc$9jQ=)
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zoNiiRc2vr4Or.#=z_S_W0bfQn$qUajEc1Q==.#=zsJ7CuUxSvlF3()
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zoNiiRc2vr4Or.#=z43pRST$NwWKm(Rectangle #=zn4Cqwqc=)
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zrRUcQWHATkbq(#=z_X60LUplbefz #=zle9Oge8=, Boolean #=zLMRAm9AbTIPcz711mg==)
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim.#=zaDxaKigo0ngN(#=z_X60LUplbefz #=zle9Oge8=, Boolean #=zLMRAm9AbTIPcz711mg==)
   at #=ztbLdcyFg9pF19zw_BhoEuu2p_Vim..ctor()
   at #=zNi5SwjbJAMGXLrmyPHQZYNyVxL3u.Main(String[] args)
A reinstall failed to fix the problem. What now?
Does everything work fine if you choose a different font?  If so, perhaps the other program you updated corrupted the Noto Sans font in some way.  If you already reinstalled MusicBee you might as well try updating it to 3.2 following the instructions in the post here:
https://getmusicbee.com/forum/index.php?topic=24754.msg146154#msg146154
if that doesnt work, send me a link to your settings file
C:\Users\<your id>\AppData\Roaming\MusicBee\MusicBee3Settings.ini
Back up and running.
It might be helpful for others to know what you did to solve the issue.
