Heya,
I used to be able to, and have had this hotkey since forever:
'General: Got To Playing Track at Source' = F
( I don't even remember if this is a default or a custom hotkey...)
And this used to jump to the playing track in the following order:
- (IF the playing track is also in the currently active tab/view (playlist/main library), no matter if it has been trigger from this view or not) -> jump to track in the currently active tab/view [which is what I really want & found to work as such when I configured/got used to using this -]
- (and IF the playing track is NOT in the currently active tab/view, and only then) -> jump to track in the tab/view it playback has been triggered 'in' / 'from'
What I do see now though is a rather different behaviour, and this seems to have started on the last version occasionally (I did use a patch from 18_05_06 last, before swapping it to the latest 3.2.6721 today), and even more extreme and differently again on the latest (= 3.2.6721), i.e. what I see, opposed to the above expected behaviour (for me):
- (IF the playing track is in the currently active tab/view) -> it jumps to a tab I do not actively use to trigger any playbacks (fyi - a tab that is set to Album Cover view with tracks only showing upon selection) - this is pretty consistent in 3.2.6721 and unwanted behaviour for me.
- in the previous version, which was from around 2018_05_06 - 'General: Got To Playing Track at Source' via F, would also jump to a differnt tab, but more consistently back to where the track playback was triggered from. Which was more consistent than the latest, but also undesirable for me.
Was there a conscious change to the ''General: Got To Playing Track' behaviour in recent versions ?
Cheers.
c.
