Author Topic: Stopping the Music  (Read 1355 times)
Lincoln
When Musicbee comes to the end of an album or playlist, it continues playing random music. I guess some people like that.
I don't.
Is there an option so that when the current album or playlist ends, the music stops?
Lincoln
Check your settings under Edit->Edit Preferences->Now Playing and set them appropriate to the result you want.
http://musicbee.wikia.com/wiki/Playback
Do you have auto-dj turned on? That's the only case I can think of where MB would play more or less random music. If it's just continuing down the list, I agree with frankz.
Lincoln
psychoadept: Thanks. It was the DJ thing.
Lincoln
So you don't like hearing random music but you turned on something called "Auto-DJ"?   :)
