Author Topic: Wavebar color  (Read 1295 times)
SoundMix
It would be a nice touch to be able to change the color of the wavebar.  8)
The wavebar color is controlled by the skin. Find the xml of the skin you're using and search for the element "Player.Wavebar" and "Player.Wavebar.Inner".
If the skin you're using is .xmlc then it's a compiled xml and you'd have to contact the skin author.
