It works P.E.R.F.E.C.T.L.Y fine !!!
EDIT1: not 100% perfect
the temporary files created are not deleted afterwards : syncing a 64 Gb card rapidly fills my 6 Gb ramdisk and stops.
(when syncing MP3 files in another location, temp files are created and deleted on-the-fly at they should).
EDIT2: my bad, the copying on the card is far too slow compared to the encoding. The files are correctly deleted. I have to reduce the number of parallel encoding
Just a subsidiary question : what is the processing behind the "resample at 44.1K" option in file converters ? (sorry I do not use the english version so maybe the text is not exactly this one). As I said I use SoX myself, but I had to install it.
Maybe I can make a few more suggestions regarding conversions :
- Using on-the-fly conversion to my mobile, I would like to leave untouched original 48/24 and 44.1/24 standard FLAC, whereas 96/24 and 88.2/24 HD FLAC are converted to 48/24 and 44.1/24 FLAC respectively.
I know there is an option to convert only files above a given rate, but I found that the rate of two different FLAC files with identical sample rate/bit depth can vary dramatically (regarding the audio content) so I cannot find a fixed rate limit above which I find all HD FLAC and below which I find all standard FLAC. So maybe the "rate" option is not the best one and could be replaced with sample rate/bit depth options.
- make functions also available in the executable line (and not only in the switches), and also give the possibility to bypass the execution of the command line with respect to a given function : this would cancel the previous suggestion.
- allow custom options for each encoder in encoding parameters.
Thanks for this great piece of software.
