Author Topic: Accessing the Start Time / End Time through tagging system  (Read 1485 times)
maziara
I was wondering if there would be a way to access the Start Time / End Time of each song. To be used in highlighting, or to display in the panels.
For example I would like to highlight the songs that have Start Time enabled for them.
Thanks
What do you mean by "start time" of a song?
I assume by "end time" you mean the length of the song, correct?
You can use a virtual tag. For instance, the following formula
$IsNull(<Start>,,<Start>)
will display start time of tracks. You can add the virtual tag to the main panel or use "that virtual has a value" for a highlighting rule.
maziara
