Author Topic: Complete freeze in 3.2.6693 when double-clicking album to play it  (Read 1199 times)
Sigma
I was playing an album and I double-clicked on the artwork of another album to play that instead. That album did not play though and instead, MusicBee completely locked up so I could no longer click on anything and I had to force close the program.
Error log info: -
30/04/2018 18:06:36 - 10.0.17134.0 - 3.2.6693.30293 - url: D:\Music\Hip-Hop & Electro\Albums\Public Enemy - Fear Of A Black Planet (Deluxe Edition)\CD1\01 - Contract On The World Love Jam.flac
System.ObjectDisposedException: Cannot access a disposed object.
   at System.Threading.TimerQueueTimer.Change(UInt32 dueTime, UInt32 period)
   at System.Threading.Timer.Change(Int32 dueTime, Int32 period)
   at #=z7KdsrVV_8ybdTlzMhq6YuFOB5STsKicqKiay3wM=.#=zumZucPYwDDokPVK$hw==.#=zHawt3E5nWfdw9L_phw==(#=zRxA8oZzmrR1QekbY5WKDdjQ= #=zNkcCD1g=, MethodInvoker #=zd1mAN4N1bFp0, #=zZUOSoX2Nuruzppu72XiIX4KxfVY3klHa$Q== #=zlTLXMkcq3t4M, Boolean #=z2tD0aNqcHeHsUh3$Jg==, Boolean #=zppn6ZLROUwud, Boolean& #=zBAUTZtFgXHSr)
   at #=z7KdsrVV_8ybdTlzMhq6YuFOB5STsKicqKiay3wM=.#=zumZucPYwDDokPVK$hw==.#=z_ZvLEoMR_bwO(#=zRxA8oZzmrR1QekbY5WKDdjQ= #=zNkcCD1g=)
   at #=zwbCZnzFqce0fNOCIJLXt$58=.#=zwRh1kvme_l42(Object #=zl7m_MoQ=)
The track mentioned in the log is the first track of the album I was trying to play.
After closing and restarting MusicBee, it seems to be working fine, but I thought I'd report this as I've never had it completely freeze up like this.
I think the error logged can only happen when MB has initiated the shutdown process, so i think its not directly related.
I dont think any more can be done unless a repeatable method is found
Sigma
Ah, OK, I understand.
If it happens again I'll see if I can figure out how to replicate the issue. When this happened I was playing one album and looking at the "Now Playing" tab, then I switched to the "Library" tab, scrolled down to a different album and double-clicked on it to play it and that caused the crash, but when I try the same steps with the same albums it works fine, so I don't know what might have caused it.
Thanks for the reply.
