Author Topic: Auto DJ apply filter not remembered after restart  (Read 1047 times)
SurfRat
Musicbee v3.2.6693
Windows 10 1709 16299.402
I have setup the filter and then selected Update. The "apply filter" is ticked.
I exit MB
I restart MB
The "apply filter" is no longer ticked.
This used to work on a previous version.
Thanks
SurfRat.
Settings are only saved when you click the Start or Preview buttons, as has always been the case.
Trying now thats working fine
SurfRat
On my setup it only saves if I hit preview first. I would in the past just press Start.
can you send me a link to your settings file (help/ support/ view settings)
