Author Topic: Corrupt display of song name in Vietnamese  (Read 1206 times)
vanhoivanbinh
I have problem with musicbee as follow
I can sync the playlist to my ANdroid phone without any problem.
On my phone using FOOBAR for ANDROID or USING GOOGLE Music stock player. There is a problem
The ENglish songs display its name well
The Vietnamese song names are crappy like below picture
The strange thing is If I use foobar for android (on my phone) to surf the playlist on the Musicbee UPNP server running on my work station, the Vietnamese song names display correctly.
I do not know where the problem is
I have tried to adjust the setting in the Sync setting but nothing is improved
Any suggestion is highly appreciated
vanhoivanbinh
I have solved this problem using foobar2000 plugin Chacon
the root cause is my Vietnamese song is tagged using non-standard font
Using Chacon, I convert all the tag to UTF-8 standard then everything is fine
