Author Topic: Accessing auto playlists give an error  (Read 1849 times)
mozartjune
MusicBee v3.2.6672.25760 (Win10.0), 19 Apr 2018 18:57:
   at #=zWr01VTn_bPhXS9_zXtraq9PXvXF$.#=zl68OgS0y2MEO(#=z60EigjoUZwY_ILvJhRb7Oww= #=z9Os8tGAudaaV, Boolean #=zPwKY5BKm2QH9, #=zv2OcCOI= #=z3BtZoYQ=, #=zlxXdb0SA1Oy1Z$5SqhLSf2A= #=zN1rIRSv6njXp, Boolean #=z3G56_V9gps0f, #=zHTXJms5SJaVZYt4S$UTHS84= #=z4lIwiivsCiN3, #=z8kghGX4PqsqdGPSz17xDkGA=[] #=zNXFy0M$R4XvA, Boolean #=zLF04Uky68RcY)
Looks like I'm unable to create new auto playlists as well. If there are additional logs/info that I could provide to help, let me know.
Note, this has been happening a while (since 3.1 I believe) so I believe it's something unique on my set up that's causing this issue.
can you send me a link to your settings file (help/support/view settings)
i am unable to reproduce any issues using your settings so let me know if you will run a debug version
edit:
could you run this version:
http://www.mediafire.com/file/5559t2gpg4p2662/MusicBeeDebugPlaylistLoad.zip
when the error happens i need the information at the end of the error log where it will say "line="  (help/ support/ view error log)
Last Edit: April 22, 2018, 11:00:58 AM by Steven
mozartjune
Here's the latest line of the error log.
2018-04-22 9:17:31 PM - line=45
2018-04-22 9:17:31 PM - location=Playlist,C:\Users\Danny\Music\MusicBee\Playlists\Added Today.xautopf
   at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
   at System.Environment.get_StackTrace()
   at #=zpTUOuizvXtp6kE2j0FzpU01YeYuc.#=zXD4545hS_qPp(#=z8XJ7UXjG$PTRk9fTFneafeo= #=zJhWp8GnTuHCf, Boolean #=zdZQSFq$EsEQW, #=z9XF6$WY= #=z8bMKTx4=, #=zVHASAau1rmyX6xVsINq6h7s= #=zHutWYZI369CU, Boolean #=z_q76cTVSg8Nk, #=zrjk8TTCiSVd6620rVeuNlzY= #=zcRBYiox026Of, #=zkIXSRN_sR3kcjri3qPncvwQ=[] #=zS67mgokb7MDi, Boolean #=z3EBO7jrdrY2M)
   at #=zpTUOuizvXtp6kE2j0FzpU01YeYuc.#=zvRkBvJjTNuLz.#=zHktvYrYWXAig(#=zqKy9M74= #=zw9$RAOE=, Boolean #=z3EBO7jrdrY2M)
   at #=zpTUOuizvXtp6kE2j0FzpU01YeYuc.#=zvRkBvJjTNuLz.OnMouseDown(MouseEventArgs #=zS9VYR_E=)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at #=zDUc00eymHcNCQEDyl736wjw=.WndProc(Message& #=zEISNTJI=)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at #=zJSHCvvO_hxuADrxLuceZ5erPcRzi.Main(String[] args)
2018-04-22 9:17:31 PM - 10.0.16299.0 - 3.2.6686.19728 - System.NullReferenceException: Object reference not set to an instance of an object.
somehow the custom view you are using for the playlist is corrupted for the artwork layout.
This will revert to the default layout if that happens
http://musicbee.niblseed.com/V3_2/MusicBee32_Patched.zip
mozartjune
Huh, that's strange. Although it has been a while since I made those playlists so maybe that explains it?
Anyways, thank you for a quick response and fix Steven. Appreciate it.
