Author Topic: DroidX syncing problems  (Read 8889 times)
thegreyspot
Hi Steven,
I am trying to sync my droidx in pc mode. I have no music files on the device. I am using a "music" folder on my sdcard. So the file structure it /music/. I have told mb to onl sync specific playlists. I also told it to delete songs that are no longer in the playlists that I want to sync.
After the first sync, everything goes just fine.
After syncing the second time, it starts to copy every song in my library, ignoring my rules. When I go to properties, the rules are still applied. The error log doesnt seem to show anything specific. Not sure what kind of information I can give you.
thanks
mike
thegreyspot
on the auto-sync preferences, only specific playlists are ticked and not 'music library' or any folders?
thegreyspot
Ehhh sorry, i thought it mean sync these playlist from 'music library'. Not the entire music library.
@thegreyspot-  are you finding that for the most part syncing in PC Mode is working?  While I haven't tried to sync MB with my Droid X (I've just dragged files over) I have tried syncing other things.  What I've found is that if PC Mode doesn't work, setting the USB Connection to Charge Only or USB Mass Storage will usually work.
@Steven- is there a way in MB to set different syncing options (i.e. playlists) for different devices?  IOW, I have an iPod on which I'd like to have different playlists than on my Droid.  If this is something that can't currently be done, and you think it -can- be done, I'll repost it to the Wishlist.
Thanks.
Last Edit: January 26, 2011, 01:57:06 AM by phred
phred, the synch settings are already specific to a device
Excellent.  I guess I should've tried it before I opened my mouth.
Thanks Steven for your foresight!!!
