Author Topic: New skin elements  (Read 100063 times)
  • MB Version: 3.6.9255 P
<element id="Player.SpectrumVisualiser" bg="252,252,252" fg="90,90,90" fg2="235,235,235" bdr="233,196,0" />
if you dont supply bg, it uses the panel background
fg is the bottom of the bars, fg2 the top and bdr for the peak bars
(copied from original post http://getmusicbee.com/forum/index.php?topic=3785.msg51036#msg51036)
edit:
added bg2 to set the bar colours when the player is stopped
Last Edit: February 03, 2013, 09:41:29 PM by Steven
set the colour for the TrackDetail view grouping header:
<element id="Content[TrackDetail].Header" fg="255,0,0" />
set the gap between library explorer header and tabs underneath
<element id="LibraryExplorerHeaderGap>1</element>
default value = 1
(see original post here)
the following bitmaps can be overridden in the main panel tool bar - all are 16x16 except where stated otherwise
PanelNewTab
PanelBack
PanelBackDisabled
PanelForward
PanelForwardDisabled
PanelRefresh
PanelStop
PanelBookmark
PanelLayout                   (28x20)
PanelLayoutDisabled     (28x20)
i think some of the skins could benefit by overridding the default icons. Its in the next 2.1 update
additionallythe following element for setting the highlight fill colour on the toolbar buttons and command buttons:
Panel.HeaderButtonOverride.Highlight
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
the following have been added mainly for the new compact player - you should set all of these or none:
<element id="Compact.LeftPanel" bg="200,0,90" />
<element id="Compact.RightPanel.Default" bg="255,0,0" fg="255,255,255" />
<element id="Compact.RightPanel.Disabled" bg="255,0,0" fg="200,200,200" />
<element id="Compact.RightPanel.Highlight" bg="255,255,0" fg="0,255,255" />
<element id="Compact.RightPanel.Lowlight" bg="128,200,128" fg="200,0,255" />
<element id="Compact.Player.Background" bg="100,200,250" fg="0,100,200" />
<element id="Compact.Player.ProgressBar" bg="190,190,190" fg="233,196,0" bdr="130,130,130"/>
<element id="Compact.Player.Control.Default" fg="40,40,240" />
<element id="Compact.Player.Control.Disabled" fg="100,10,100" />
<element id="Compact.Player.Control.Highlight" fg="180,80,80" />
<element id="Compact.Player.Volume" fg="100,100,100" bdr="110,110,110" />
<element id="Compact.Player.Wavebar" fg="223,184,60" fg2="45,145,190" />
<element id="Compact.Player.Wavebar.Inner" fg="193,156,30" fg2="130,30,230" />
<element id="Compact.Player.MetroButton.Default" bg="20,55,10,200" bdr="40,200,90" />  - dont set bg if you dont need a fill colour
<element id="Compact.Player.MetroButton.Highlight" bg="80,255,0,100" bdr="90,220,220" />  - dont set bg if you dont need a fill colour
also to set the metro buttons in the main player (when the main player is configured for modern layout and has the wavebar displayed):
<element id="PlayerFlat.MetroButton.Default" bg="20,55,10,200" bdr="40,200,90" />  - dont set bg if you dont need a fill colour
<element id="PlayerFlat.MetroButton.Highlight" bg="80,255,0,100" bdr="90,220,220" />  - dont set bg if you dont need a fill colour
Last Edit: June 02, 2013, 10:09:52 PM by Steven
to override the "Unknown Artist" image in the artwork layout
<element id="UnknownArtist">...bitmap data...</element>
to override the playing track tab icon:
<element id="PlayingTrack">...</element>
<element id="PlayingTrackInTab">...</element>
to override the visualiser icon:
<element id="Visualiser">...</element>
to override the "Lyrics" header when configured with a vertical stack (used in the Melon Remixed skin)
<element id="NowPlayingPanel.SectionHeader" bg="0,244,0" />
to hide the arrows in a scroll bar:
<element id="ScrollbarNoArrows">true</element>
"PlayerFlat.Control.Highlight" now accepts bg and bdr, where you might set an alpha component on the bg colour so you can get a highlight box around the player controls on mouse over
to override the new sub-header colour in the Album and Tracks layout
<element id="Content[AlbumAndTracks].SubHeader" fg="120,120,120" />
to override the icon used for the "Search Results" node:
<element id="SearchResultsIcon">...bitmap data...</element>
as of MusicBee v2.3.5139:
to override the icon colour used for command buttons when the user has set the icons to be recoloured to the skin
<element id="Panel.CommandIconOverride" fg="245,0,0" />
to specify the text colour for highlighted items in a drop-down menu
<element id="Menu.DropDown.HighlightText" fg="255,0,0" />
to override the progress button when the player is docked to the right sidebar
<element id="PlayerSidebar.ProgressButton" fg="244,0,0" />
to override the colour used for the tag editor header bar when docked in the main panel
<element id="TagEditorPanel.Header" bg="255,0,100" fg="255,255,255" />
to put a border around the search box in the main panel
<element id="Panel.SearchBox" bdr="255,0,0" />
to put a border around the scroll bars - its only supported for when no arrows are displayed
<element id="Panel.ScrollBar.Default" bg="210,210,210" bg2="200,200,200" bdr="190,190,190" />
to override the separator line that groups albums when the Album And Tracks layout is used in the Now Playing list
<element id="NowPlaying[AlbumAndTracks].AlbumSeparatorLine" bg="255,0,0" />
to change the rounding on the caption bar:
<element id="UseSquareCaptionBorders">XXX</element>
XXX=Always; Win8+; Never
When Win8+ is used, the skinned caption bars need to work as rounded and as square depending on the user's OS version
to override the column headers in dialog panels
<element id="Controls.ListHeader" bg="255,0,0" bg2="0,100,200" fg="255,210,255" />
to override the background colour for the right sidebar - it doesnt really affect much other than when the player, visualiser or wavebar is docked in the sidebar
<element id="Sidebar.Body.Default" bg="100,100,100" />
Last Edit: January 26, 2014, 09:02:29 PM by Steven
to override the progress button in the various player modes:
  <element id="PlayerSidebar.ProgressButton" fg="24,0,100" /> ' defaults to button control
  <element id="PlayerFlat.ProgressButton" fg="25,196,0"/>  ' defaults to bar colour as now
  <element id="PlayerTopFlat.ProgressButton" fg="25,196,0"/>  ' defaults to PlayerFlat.ProgressButton as now
  <element id="PlayerMini.ProgressButton" fg="2,146,190"/>
  <element id="Compact.Player.ProgressButton" fg="253,96,0"/>
forgot to mention these:
i have added the following overrides - this only activates for the now playing list docked in the left or right sidebar (and not when its docked in the bottom of the main panel)
  <element id="NowPlayingList[TrackDetail].ListHeader" bg="40,240,240" bg2="225,5,5" fg="0,210,0" bdr="255,80,80" />
  <element id="NowPlayingList[TrackDetail].Default" bg="55,255,255" fg="0,200,0" bdr="200,2,100" />
  <element id="NowPlayingList[TrackDetail].Highlight" bg="45,236,172" bdr="227,216,152" fg="0,220,20" />
  <element id="NowPlayingList[TrackDetail].Lowlight" bg="35,235,235" bdr="25,105,25" fg="0,250,40" />
  <element id="NowPlayingList[TrackDetail].Disabled" fg="70,70,0" />
  <element id="NowPlayingList[TrackDetail].ListAlternating.Default" bg="48,248,248" fg="0,210,0" />
  <element id="NowPlayingList[TrackDetail].ListAlternating.Disabled" fg="70,250,170" />
  <element id="NowPlayingList.ScrollBar" bg="200,200,0" bg2="180,10,180" bdr="235,40,255" />
  <element id="NowPlayingList.ScrollBarThumb" bg="20,230,230" bg2="20,20,250" fg="200,00,180" bdr="200,90,0" />
  <element id="NowPlayingList.ScrollBarBackground" bg="30,230,30" bg2="250,20,250" />
this applies to the column browser, thumblist browser and the podcast subscriptions browser:
  <element id="FilterPanel.ListHeader" bg="40,40,40" bg2="25,25,25" fg="200,250,150" bdr="255,40,20" />
  <element id="FilterPanel.Default" bg="40,40,40" fg="200,200,200" bdr="20,20,20" />
  <element id="FilterPanel.Highlight" bg="45,26,72" bdr="27,16,82" fg="220,100,200" />
  <element id="FilterPanel.Lowlight" bg="35,35,75" bdr="25,25,65" fg="100,200,100" />
  <element id="FilterPanel.Disabled" fg="170,170,170" />
  <element id="FilterPanel.ListAlternating.Default" bg="48,48,98" fg="220,220,220" />
  <element id="FilterPanel.ListAlternating.Disabled" fg="170,170,170" />
  <element id="FilterPanel.ScrollBar" bg="200,200,0" bg2="180,10,180" bdr="235,40,255" />
  <element id="FilterPanel.ScrollBarThumb" bg="20,230,230" bg2="20,20,250" fg="200,00,180" bdr="200,90,0" />
  <element id="FilterPanel.ScrollBarBackground" bg="30,230,30" bg2="250,20,250" />
for the next v2.4 release, the following scrollbar overrides are available for the left navigator
  <element id="LeftNavigator.ScrollBar" bg="210,0,0" bg2="200,200,200" bdr="0,190,10" />
  <element id="LeftNavigator.ScrollBarThumb" bg="30,230,230" bg2="50,20,250" fg="100,100,00" bdr="0,0,0,0" />
  <element id="LeftNavigator.ScrollBarBackground" bg="30,30,230" bg2="250,20,250" />
i will also add for the next release:
  <element id="Panel.ChildBody.ScrollBar" bg="210,0,0" bg2="200,200,200" bdr="0,190,10" />
  <element id="Panel.ChildBody.ScrollBarThumb" bg="30,230,230" bg2="50,20,250" fg="100,100,00" bdr="0,0,0,0" />
  <element id="Panel.ChildBody.ScrollBarBackground" bg="30,30,230" bg2="250,20,250" />
this will enable the scroll bar in the library explorer and Now Playing panel to match the panel colours
Last Edit: March 08, 2014, 06:37:11 PM by Steven
for the next v2.4 update, to override the new soundcloud Track Search icon
<element id="TrackSearchIcon">...bitmap data...</element>
these are available in the latest v2.4 patch version
to override the tabs when displayed in the caption bar:
<element id="CaptionBar.HeaderControl.Default" fg="190,190,190" />
<element id="CaptionBar.HeaderControl.Disabled" fg="120,120,120"  />
to override the colours used for the status bar when the player is docked on the bottom:
<element id="Panel.StatusBarInPanel.Default" bg="245,245,245" fg="95,95,95" bdr="230,230,230" />
and this overrides the panel open/close buttons:
<element id="Panel.StatusBarControlInPanel.Default" fg="140,140,140" />
to force musicbee to display the status bar in the main panel when the player is docked down the bottom (I might remove support for this):
<element id="AllowStatusBarInPanel">true</element>
to show a vertical separator bar between each inactive tab:
<element id="TabsBar.Tab.Separator" bg="180,180,180" />
<element id="TabsBarBelow.Tab.Separator" bg="180,180,180" />
<element id="TabsBar.TabInCaptionBar.Separator" bg="180,180,180" />
override the artwork panel scrollbars:
<element id="Content[Artwork].ScrollBar" bg="150,150,150" bg2="130,130,130" bdr="0,0,0" />
<element id="Content[Artwork].ScrollBarThumb" bg="255,255,255" bg2="255,255,255" fg="123,123,123" bdr="255,255,255" />
<element id="Content[Artwork].ScrollBarBackground" bg="250,250,250" />
overrides the colouring used under the tabs bar when MainPanelTopBorder is true
<element id="MainPanelTopBorderColour" bdr="180,180,180" />
Last Edit: August 02, 2014, 01:45:46 PM by Steven
