Author Topic: how do i fix this sorting problem - songs get multiplicated and mixed up  (Read 1101 times)
whatever_whatever
So. Im on my way to finally clean up music library, ditched WMP, sorted ALL tags, added ALL artwork manually. And i see this:
https://i.imgur.com/jlaTqdK.jpg
I cant find any info about it, and tags seem to be fine. Its a two disc version, second disc gets multiplicated same way. Another album shares same story. Note that under same name are different songs, not same ones replicated. For example: first one isnt Black Sabbath, its The Warning
Any ideas? Should i just make it one disc?
Probably they are files with embedded cuesheet. Check with tag editor and tag inspector.
To clear them up, select files> right click> Remove cuesheet.
i recall i made some enhancements in the patch version to help prevent this happening in the first place
http://musicbee.niblseed.com/V3_2/MusicBee32_Patched.zip
whatever_whatever
That worked perfectly, Thanks :)
