Author Topic: Distorted sound  (Read 1352 times)
wout31
Hello,
I have a question about the following issue I have with Musicbee.
When I start the first track after starting Musicbee, the sound is distorted.
Restarting the track without restarting Musicbee solves the problem.
Same problem when going fast forward in a track. Distorted sound.
Restarting the track solves the problem.
Tested the same track and same sample erates with Foobar 2000. No problem.
Plays coreect on the first start and plays correct when going fast foward.
Is there a setting wrong? I checked everything, but kind find a sollution.
Who can poin t me in the right direction.
Regards
Jos Wouters
The Netherlands
Maybe you have trim starting silence enabled in the player preferences; the remove silence plugin installed or its the effect of a DSP you might have active.
I have no other suggestions
CritterMan
  • Now with FiiO M11!
 Are you using DirectSound, WASAPI, or ASIO?
