Author Topic: "Sync Play Count from Last.fm" not working properly  (Read 3349 times)
-L0Lock-
Hi there!
I've been using MusicBee & Last.fm for several months now, but I noticed that even when I manually launch "Sync Play Count from Last.fm", it doesn't sync perfectly all my tracks.
Here's an example :
Those are my most listened tracks since I use Last.fm :
And here are those from Musicbee after syncing the play count from Last.fm :
Notice that they are not the same. All these tracks get their play counts updated if I play them, but some with wrong values.
If I play one of my top 10 tracks from Last.fm, it gets scrobbled in last.fm but if I launch a sync in Musicbee it just says nothing has changed.
It's like MusicBee ignores some tracks when he has to update them.
I tried to log off and in Last.fm in MusicBee, no change.
Any idea? Thanks!
vanhoivanbinh
Hello, I have similar problem
Sometimes the playcount sync, other time it is not
vanhoivanbinh
I found that this problem is specifically with Asian character song name (like Chinese, Japanese and mines are Vietnamese)
