Author Topic: Custom web links: add "myzuka"  (Read 5373 times)
stardepp
I often use the music website Myzuka (https://myzuka.club/) to legally stream ripping music using Audials software.
Therefore, it would be very useful to create a custom web link from "https://myzuka.club/" in order to be able to send a link to the default browser directly from MusicBee from the artist currently selected in MusicBee Example Evanescence: https://myzuka.club/Artist/367/Evanescence.
So like "https://www.google.com/search?&q= <artist> band"
Is that possible?
Last Edit: March 31, 2018, 06:51:31 AM by stardepp
Is that possible?
Have you tried substituting myzuka.club for google.com?
What is the number in the /367/ part of the url? Is that something myzuka generates? If it is, then you'd have no way to know it from MB and couldn't generate the tag.  If it's not needed, then it possible.  If you need that, I don't see how you'd make that link unless you somehow scraped the myzuka site for all the values and then imported those values to MB in a custom tag (complicated).
stardepp
Yes, I tried "https://myzuka.club/search?&q=" but this was acknowledged by Myzuka with an error message.
Myzuka numbered his artists numerically upwards, so Evanescence got the number 367. Removing this number from the URL invalidates the Myzuka URL.
Myzuka has a larger selection than Spotify.
I've already recorded 56,000 songs at Myzuka.
If you could somehow get the myzuka id into your tags as a custom tag then you could do something like "https://myzuka.club/Artist/<MyzukaID>/<Artist>" as a custom web link.
Because of how they've structured their links, it doesn't seem like you have any options other than that.
stardepp
That did not work that way. But maybe it is with the album search of Myzuka: https://myzuka.club/Albums. Otherwise it is not so bad. Nevertheless thanks for your help.
