Author Topic: "Guest Artist" handling changed in 3.2?  (Read 1697 times)
Tybot
I recently noticed a difference in tracks tagged with 3.1 vs. 3.2.
In "Multiple Artist Splitter" you can choose "Guest Artist" from the drop-down menu. If you do that and check the tags using tag inspector it will look something like this:
ALBUM ARTIST The Beatles
GUEST ARTIST Justin Bieber
PERFORMER John Lennon (Guitar)
In 3.1, if you instead of using the drop-down menu manually typed in "Guest Artist" in the "role/instrument" field your tags would look like this:
PERFORMER Justin Bieber (Guest Artist)
I just checked a track tagged with 3.2 and even though I typed the role as "Guest Artist" in manually, tag inspector present the tags as in example 1.
The only thing I've done differently is updating MB to the latest version. Bug or expected behavior?
Tybot
yes it looks like a bug in v3.1
That's a shame. Was hoping it was a bug in 3.2. Is there any way to sort the guest artist under performer in 3.2 or do I have to change the wording to just "Guest"?
This is a change from how MusicBee has behaved in the past.  Why is guest artist no longer its own tag?
it is. It appears an older v3.1 might have had a bug around this
Oh, I.think I read it backwards, sorry
