Author Topic: date format  (Read 3435 times)
c0nm4n
musicbee currently uses the american date format. it could provide at least one of these two date format options:
1. use system's format
2. user-defined format
i would really like to switch to 24h format and get rid of AM/PM, as it is in windows :)
musicbee uses the windows settings not american format. Couldnt you just change the windows settings to how you want?
KeeWee
MusicBee does NOT use system settings ... I too have the same problem with it using damn American system.
My system settings are - YYYY-MMM-DD HH:MM ... MusicBee is NOT using leading zeroes and also attaching a.m. / p.m.
Please fix ... or I'm afraid, MusicBee will end up in the bin with iTunes !!!
KeeWee
Hmm ... appears MusicBee sort of uses the system setting ... as when I cleared the AM and PM fields from the system regional setting, they also disappeared from MusicBee
BUT ... the time still shows up in 12 hour and not 24 hour ... so, MusicBee does not entirely use system setting !!!
VX
...or I'm afraid, MusicBee will end up in the bin with iTunes !!!
Even if you have found a bug in MB you shouldn't have written this empty threat. What are you going to achieve with that  ???
Steven is so great developer that he fixes all noticed bugs as soon as possible. Just have a deeper look at the Bug Reports section on the forum.
You could provide more feedback (if needed) to get this bug fixed...
And please avoid threats on the forum, will you  ???
