Author Topic: Lockdown Feature  (Read 31270 times)
VX
Steven, thank you very much for the "disable web access option" in MB 1.2.4040 :)
I'd mention that if you lock the player with this option enabled while using any of the internet websites in main panel, the lock won't work for the links at the website. Furthermore, if you lock the player while browsing the Upcoming Releases service, not only the links on the website will be active, but you can also use all the Internet services available from the Playing Artist info bar (i. e. Last.fm, Wikipedia, local Wikipedia, YouTube and All Music - if the last one is enabled in the preferences; I wouldn't recommend to use the AllMusic as it doesn't work until you enter the artist name into the search box manually).
I wouldn't call it a bug, I just want to make sure you know about it.
