I cannot access any Properties of this folder. I cannot change the Owner status of the folder. The folder contains no data and shows up as having no bytes when I look at its properties. Any other access to this folder is denied.
I have been out to the DOS command lines. Access is denied when I try to delete this folder. Also, in DOS, an attempt to set the directory path to this file says that the folder does not exist.
I believe this folder actually does not exist.
History: the folder originally existed with over 500 GB of data and was in use without issue. I decided to delete this folder. All sub-folders and files were deleted in the normal manner. However, the folder itself remained and was not deleted during the deletion process.
I suspect that the folder has somehow become corrupted or is a "phantom" folder. But, I need to get rid of it so that I can reuse the folder name.
Thoughts?
Thanks,
Art
