Author Topic: DiscordBee - Updates your Discord status with Infos from MusicBee  (Read 105934 times)
kilo
Question (not related to my previous posts on here): isn't DiscordBee supposed to show the total and elapsed time of your current song in your Discord status? It still shows album, song name, and track number, but this has been gone for months. Was it removed?
nekothegamer
please i need help, i want it to work back it's the reason i use musicbee in the first place
spencey
Mine is completely broken since early September. Using the current version 3.0.4. I've tried deleting old files in roaming %appdata% but doesn't really do anything. It just seems the whole thing is broken since the ID thing changed with discord. Very sad, because I loved the RP integration. It was cool to share what bootlegs or whatever odd music I was listening to with my friends, but there's an end to everything eventually..
my version of Musicbee is 3.4.8033
duncebee
claphands
I'm currently on the Nov 27th build (3.5.8367) with no issues. You might want to go back to that version, if possible. I'm going to wait to upgrade I guess.
For completeness, last time I updated was September 2020 (3.4.7792) also with no issues.
tvlh
Hi. Seems like DiscordBee isn't uploading the album covers. How can I fix this?
Thank you in advance.
thequietkid
Can someone please help me with this?
I am getting this "Unable to initialise plugin" error message when trying to enable this plugin from the musicbee preferences menu.
greusch
Can confirm this is happening for me as well. I was noticing that my album art uploads were no longer working in DiscordBee 3.0.4 even with a custom Imgur ID, but until there's a workaround or fix for this I am unable to update.
Rowann1
My MusicBee has been crashing multiple times a day for the last year and a half. Finally reporting it.
Error:
MusicBee v3.5.8150.17011D  (Win10.0), 24 Jul 2023 22:04:
   at MusicBeePlugin.DiscordTools.DiscordClient.<UploadArtwork>d__22.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_1(Object state)
   at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
This shows the problem is with the Discord Bee plugin.  Try updating the plugin to its latest version (https://github.com/sll552/DiscordBee/releases) first, and if errors continue post in that plugin's forum thread so its developer can see them.
