Author Topic: Swedish - Svenska (updated 2022-06-20)  (Read 18001 times)
swedishme
Nu är den äntligen klar, översättningen till svenska. Det finns en redigerbar version LNG samt den binära LNGC.
Uppdaterad:2022-06-20 SWEDISH
File:Svenska.lng(MusicBee v. 3.5.8150)
Textfilen läggs i Program-mappen\MusicBee\Localisation
Du behöver starta om programmet efter du bytt till svenska för det ska fungera.
Last Edit: June 20, 2022, 10:17:45 AM by swedishme
here is the binary version:
http://musicbee.niblseed.com/Weekly/Localisation/Svenska.lngc
i will include it in the next official MusicBee release
colorizing1
Its me, my e-mail has been deleted cause I didn't watch it for a year (I used mostly a plugin to send all my emails to another email). I don't know how to open up again.
Well, thats not what I wanted to say. I found a few errors, not many but I want to fix them. Do you have the language-file? I tried to download from my link but it does not work anymore.
swedishme
Thank you, I also have a question.
There is a problem. Its a space on some in the list when searching. I don't know how to fix this, I tried to delete the space in the text-file but it does look the same.
Last Edit: November 08, 2018, 09:51:25 AM by swedishme
swedishme
Now the file is updated, still the "space" on some places like when searching for files is still there.
its because you are using a space and not a tab as the separator.
I suggest you do a global search/replace of "# " with "#<tab>"
Last Edit: November 12, 2018, 08:43:03 PM by Steven
swedishme
A, I saw many of them had a space, wierd, might be cause I used the old swedish as a template for some or that I did it without notice it. Now they are replaced with tabs and works perfect. :)
swedishme
Why didn't the new "Released on November 26, 2018" include the new translations?
not intentional - it will be in the next release
swedishme
I will reupload it tomorrow again. It seems like it has dissapeared on the folder I put it up to.
EDIT: I have reupload it and added a backup. I have been gone for a while without internet connection.  :)
Last Edit: June 05, 2019, 11:13:18 AM by swedishme
swedishme
