Author Topic: Same Album Title - Different Year  (Read 1184 times)
Smudger
Hi
Just a small situation and that is if an artist has released an album say in 1997 with 10 tracks ie Andy Williams - Greatest Hits and then re-released that album in 2000 with one additional track. The artist is the same name and the album is the same name MB recognises it as one album - is there a way around this please or can MB add new entries by folder.
Steve
CritterMan
  • Now with FiiO M11!
The way I handle this is to place all files for a specific album in the same folder and then click the radio button for grouping by folder. boroda74 gave the location above. You can also try to tweak the rules by which MB specifies what is in the same album. I recommend the folder option, less likely you'll have issues if your tracks are not tagged completely uniformly.
