Author Topic: Album List  (Read 4365 times)
Smudger
Morning All
Is there a way to generate a list purely just of the albums and not tracks ie
Simple Minds - Greatest Hits - 2018 - 17 Tracks - 58:01:14
Regards
Steve
Not exactly the way you describe, but see if the Collapse Albums setting gets close: http://musicbee.wikia.com/wiki/Tracks_View#Collapse_Albums
Smudger
Thanks for that, excuse me for asking but where can I find Group By menu
Steve
Smudger
Found it thanks, but can't send to Library Reports when collapsed.
Thanks Anyway
just add groupings in 'library reports': 'album artist', 'album' and aggregated function 'sum(duration)'. its if i understood you correctly.
Smudger
Now that is just perfect - thank you
you might want also to add 'count(url)': its for number of tracks in album.
Smudger
Had a play with that also and works a treat - thanks ever so much
Smudger
The 'count' for tracks isn't reporting correctly however the time is - just noticed it once on an album with 14 tracks and reporting 1 track although the total time for the artist is exact
is that album a cuesheet file? if so its not supported. more exactly you can try 'count(title)', but all titles in album must be unique (sometimes - rarely - its not the case).
edit: also you can try 'count(track number)' if all track's numbers are filled correctly (i.e. unique).
Smudger
thanks for that will try and report back
Smudger
Hi Boroda - I think I may have misunderstood your original post here:-
'count(url)'
what is the (url) part
thanks
Smudger
Hiya Boroda - all working perfectly thanks ever so much
Steve
