Author Topic: Can't Remove Album  (Read 1419 times)
tcdodge
I have an album that shows up as unknown with 11 tracks simplay called Track XX. When you click on a track, it says source file can not be found. I can't figure out how to remove. There is no corrresponding folder in my music directory.
Definately a first world problem but like to get rid of if I can.
Thoughts?
Thanks.
Tom
It may not be in your music directory.
Right-click on the album or track(s) > Search > Locate in Computer Node. Once found you should be able to delete it.
OR if MB still doesn't find it
Right-click on the album or track(s) > Search > Locate in Windows Explorer > Delete
tcdodge
Used locate.  It shows it mapped to a virtual (connected) drive (D:). My only devices are my .mp3 player. When I plug that in, it can't find the files on that either.
Thanks.
