Author Topic: File no longer exists / Error upon trying to re-locate the file  (Read 2101 times)
SHODAN
ERROR LOG:
MusicBee v3.1.6512.37408 (Win6.1), 11 Jan 2018 14:59:
System.FormatException: Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
   at System.Text.StringBuilder.AppendFormatHelper(IFormatProvider provider, String format, ParamsArray args)
   at System.String.FormatHelper(IFormatProvider provider, String format, ParamsArray args)
   at #=qoYblrTMB_oQ5AT5glRNE55AEa7FDj35oazlKjOrGqBo=.#=qHAaJvEIQPELVcjg8EKpgglC5gxcesKctnbsAHMq8YtI=(#=quBTWLQEpz_JUjVbEDhFEctQwOG2OitHuzwxFzOvQKk0= #=qdHnONw02Ty3dNaNZ7bepaA==, Boolean #=qjLVf$5l1iEBgLvVeGrzLMg==)
   at #=qjQOxtZn2Va9io65yZWhKzsjCki96TM_Bk$Kz6$guMcM=.#=qcQi4f$4HGjmWVaE7l_ElukFDOz0DMPd5z_eUMeY4eK8=.OnMouseDoubleClick(MouseEventArgs #=qAORkZ8CjkXY7SQ7MhKMOXQ==)
   at #=q$GkCRTq_VzlugJq8lyXrXMkcOEAVG5HWYZPfBMXOHoM=.WndProc(Message& #=qSrcewrmBmS_57FGACXHvfg==)
STEPS:
Rename a music file in windows explorer
Find the track in MusicBee music tab / search tab / playlist tab (doesn't matter which)
Ctrl + S = "The following files no longer exist at their location... remove them from library?"
Select NO
Double click the missing file to trigger a locate missing file window
Error occurs
VERSION:
OS: Windows 7 home premium
MusicBee: 3.1.6512
I do a LOT of file re-location and never seen this error before... at least until I installed this version of MB a few days ago
are you using a language version of MB and if so, which language?
if not, can you update to the latest version from the first forum topic
SHODAN
hi mate,
I'm using the standard English version downloaded directly from here:
https://getmusicbee.com/downloads/
EDIT:
the same error is occurring in version 3.1.6585
I left out some important information in the OP:
this error occurs when trying to re-locate files in directory #1, but not directory #2. for example:
Z:\LABELS\P\Pinkman\YYYY - Artist1 - Album1
Z:\LABELS\P\Pinkman\YYYY - Artist2 - Album2
I change the filenames in both directories, then re-scan the files in MusicBee
error for all files contained in directory #1
no error for all the files contained in for directory #2
I tested this with identical filenames and identical tags (artist, album, track title and track number; all other tags deleted using the extended tag viewer in mp3tag)
the directory character length is also identical (well under 255)
directories #1 and #2 live on the same hard disk
the music files are identical, except for the filenames and tags. I checked them in AudioTester and they passed with no error
testing more...
- set the filenames in directory #2 (the "bad" directory) to the original expected filenames
- rescan, no problem
- change the filenames in directory #2 to something unexpected
- rescan
- double click to trigger re-location window - error
- change the filenames back to the original expected filenames
- rescan, no problem. play the file in MB, no problem
testing...
- change the filename in directory #2 to something unexpected
- start a full MB re-scan for new files
- confirm the removal of the old files from the library
- play the file, no problem
- change the filename again
- rescan
- double click to trigger re-location window - ERROR
testing...
- move the files to a different folder altogether (directory #3)
- change the filename again inside the new directory (directory #3)
- rescan
testing...
- create a new directory (directory #4)
- copy/paste (not move!) the files from directory #3 to directory #4
- change the filename again inside directory #4
- rescan
- double click to trigger re-location window - NO ERROR. all good!
final test...
- copy/paste the files from directory #4 to directory #2 (or #3)
- delete the files from directory #4
- change the filename again inside directory #2 (or #3)
- rescan
- double click to trigger re-location window - ERROR!
I can't figure this one out at all
Last Edit: January 15, 2018, 11:43:28 AM by SHODAN
there is only one place the error can be and thats the reporting message that MB displays. Is it possible the filename contains "{n}" where n is a digit?
edit:
could you try this version:
Last Edit: January 15, 2018, 07:48:11 PM by Steven
SHODAN
nope. the filenames do not contain "{n}" or any other problematic characters. the filenames go like this:
01 - Artist - Track Title
no leading / tailing spaces, no foreign characters, no other numbers except the track number
