Author Topic: 'Spooky Black' Skin  (Read 48079 times)
Rotem K.
Rotem, I'm looking for Artist Information header and Playing track header.
Please help ;]
That will be the element: Panel.TabSelector
Panel.TabSelector.default will fix the BG colors on both.
and .highlight and .lowlight will fix the selected tab and mouseover colors in the artist info panel.
Last Edit: January 14, 2011, 03:51:27 PM by Rotem K.
Hi
 I have just been playing with the skin and using the following line...
<!-- 109-->  <element id="Controls.InputControl.Default" bg="100,100,100" fg="200,200,200" bdr="85,85,85" />
I can set bg to alter the background of an input cell and bdr to set the border colour and I thus assumed that fg would be the text colour, however the text in box (eg in the edit menu) is black and I can find no effect when changing the value of fg.  Have I made a wrong assumption and if so how can I set the text colour or have I got a bug?
Thanks
Dave
Hey Dave,
You've made the right assumption but, the input elements are in a bit of a mess. that FG in inputControl.defualt will change the color of text inside scrollboxes (like in the hotkey tab in preferences menu).
And as for right now there is not way of to color editable-text in text boxes.
i've fixed it now so Controls.InputControl.Default should be used consistently thoughout the application
http://www.mediafire.com/?8gkacn9kc08xqas
Rotem K.
just one thing which i cant (or dont know how to) do is set the colour when selecting text in a text box - its takes the colours from the windows settings. So the highlight colour settings only affect listboxes and dropdown boxes
daak_grey
Thanks for the change Steven, it came as a nice surprise when I did the last update!
Rotem K.
UPDATED LINK
Changes:
- Mini-Player Now Playing list toggle button.
- Modified Text color [in edit screen] .
- Locked Text in locked Text Boxes.
- Brighter Window Buttons, elevated a bit.
- Round Bottom Borders.
Known Issues:
- Mini-Player Volume Button.
- UP and DOWN buttons in 'Other Fields' menu.
Last Edit: February 01, 2011, 01:00:59 PM by Rotem K.
Rotem K.
UPDATE LINK
Changes:
- Highligh buttons.
- Fixed a bug regarding the star rating.
Rotem K.
UPDATED LINK
Changes:
- Save icon in edit screen [when docked in the main panel].
- Edit screen toolbar buttons [when floating], highlight.
- A-Z bar.
- "Track Information" and "Now Playing" in the right side panel background color.
First Exe to support new elements :
ver 1.2.4061 :: http://www.mediafire.com/?zbk48cqns5kli4m
Last Edit: February 13, 2011, 10:06:26 PM by Steven
tryguy
Hey Rotem, I really like how you've layed out your interface.
Oh, and I like the skin, of course.
Could you tell me how to make my layout like yours? Is there a file I can download, or do I have to fiddle with things from the Quick Layout... option?
Rotem K.
Hey tryguy,
Open View menu in the menu bar,  click Quick Layout, and in the screen that appears select the first option that has "Now Playing List in Main Panel".
tryguy
Rotem K.
Updated link.
Changes:
- Radio directories.
- in download indicator color.
