Author Topic: Ability to lock the panels.  (Read 3569 times)
wealstarr
Hello,
Whenever I try to reach for the scrollbars, I sometimes accidentally end up dragging the panels around. In my opinion, with panels being configurable, it would a good option to be able to lock them down once the set-up is finished, especially with that narrow scrollbars option.
The relevant thread is here where I asked if I can lock 'em down and I'm creating this topic on suggestion of a Moderator.
Thank you for reading.
CritterMan
  • Now with FiiO M11!
+1
this is done for the next v3.2 update. Its set in the layout preferences
