Author Topic: Playlist Sync to Walkman S639  (Read 7552 times)
smegg
Hello,
I love MusicBee having only discovered it a couple of weeks ago, following years of MediaMonkey (which seems a little bloated now) ;D
My only problem, which I have had with updates of other media players, is that I cannont get the playlists to be read by my older sony player. It requires .PLA playlist files.
Any ideas?
Thanks
Greg
MB supports .PLA playlists when using MTP mode - do you have MTP mode enabled in the Devices preferences?
If you do, its possible there is a problem when MB detects whether the device supports this format
ferongr
I have a same-gen Sony player somewhere, will dig it up and find out if it works for me and if not, why.
ferongr
Apparently I could not get my player to connect over MTP (it's stuck in MSC, stupid driver caching).
