Hi Fred Barker,
Thanks for your insights. Maybe I should be a little bit more specific so you'd understand my question.
I got the Add files to library part. I was able to import my library from iTunes and everything worked perfectly, not missing any songs or anything. I have a habit that when I download new songs, I would drop them to a "New music" playlist instead of the main music library, just to keep track of what songs I downloaded, and because I listen to the new stuff more often. Normally for iTunes, when I add a new song to a playlist, it will also be added to the main library, but I've noticed it's not the case for Musicbee. After I add new songs to the playlist and search for them in the Music panel, they won't show up until I manually drag these songs from the playlist to the music panel.
So I am just wondering if there is anyway to make Musicbee automatically update any songs that I add to the playlist to the main music library? I would hate to miss on any songs.
P/S: Musicbee is soo much better than iTunes in terms of audio quality and features. I cannot believe I just knew about it today. >
