Author Topic: Help identifying missing files  (Read 11539 times)
Dgonix
Hello. tell me, here I pointed the player, from which folder to take the music. yesterday, from this folder, deleted 1 song, and 2 added. the player did not see the changes. advised - to close and open the player, did not help. Advised to press F5, also no use. I had to re-scan ... maybe, who knows, the way is easier?
Are you saying you have configured that folder as a monitored folder? Then it's strange. If it's continuous monitoring setting, it should have detected the changes right away. If it's scan on startup only option, restarting should notice the changes (if your library is big, wait until scanning gets done). Try again to see if you can replicate the issue.
Last Edit: December 25, 2017, 10:49:50 PM by redwing
