Author Topic: "Use Relative File Paths" Makes no difference in my exported playlists  (Read 1153 times)
brentoma589
Hello all,
I am trying to export M3U playlists with relative paths. When I right click and export one of my playlists, the playlists have the exact same C:\a\b\c path regardless of whether I check the "use relative file baths" box or not. Please advise. Thanks!
Make sure the exported playlists are on the same drive as the files to use relative paths.
