Author Topic: How to set MB Volume to the same maximum as other programs?  (Read 1407 times)
WimYogya
I noticed that the maximum volume when playing MB on my PC is a LOT lower than the volume I use with an external audio player like XMPLAYER or my videoplayer VLC.
Cannot find the cause of the difference but would like to use the same maximum volume for all.
How can I do that?
Thanks,
Wim
Last Edit: November 27, 2017, 10:35:29 AM by WimYogya
WimYogya
retired Dutchman (1944) in Yogyakarta, Indonesia
[email protected]
I'm only getting about 1/2 the volume thru MB as with Windows Media Player. I must have settings screwed up.  Help?
Thanks
Check Windows Volume Mixer (right-click the speaker icon by the systray clock and choose "Open Volume mixer") and be sure the slider for MusicBee is at 100%.
SkyZippr
Also make sure you're not turning replay gain on. For most modern pop music, it lower the volume to normalize it.
