Hi hiccup.
I wanted to give you an answer to your request here.
So I have the technical ability to at least give it a try, as far as the my CEN plugin covers the most aspects you ask for. So that's a yes.
What stops me are two things - time (as always) and the strange bin image files. Did someone have progress on interpreting those files? Any links or knowledge on that is welcome for me.
Hey! That's great kamen!
I won't get my hopes up yet, since I can imagine this is something that will be very time-consuming, and far from straightforward. (if even technically possible)
Me having no coding capabilities I probably won't be able to provide much useful help with this.
But I should still have lots of files on my computer that I used for testing and trying to figure out how this VU meter magic happens for the foobar2000 plugin.
So I should be able to provide you with some relevant files and stuff that I extracted (of which I only have a faint guess of how they work exactly)
I'll refresh my memory on that, and see what I can come up with.
Ah, OK! Since the subject is being actively discussed now it deserves to be its own "New Topic" under the Visualisers child board, not an over-entended "Wishlist" entry. Kamen (or hiccup) I would urge you to create that New Topic name and I hope it takes off this time, it was almost there too! It would be great to have this.
While I understand your reasoning, I'm a bit in two minds about this.
The topic it is in is the Wishlist board, and until now it is just that, a wish.
And it can be discussed here further perfectly as far as I am concerned.
My interpretation is that the Visualisers board is more intended for available visualisers.
A better board for this kind of stuff could be the Developers board?
I'm slightly reluctant to add a second topic about pretty much the same while this one already contains so much info on the matter
But then again it might be good to have a fresh topic in 'Developers', with a start post that contains relevant information for coders from this thread (and perhaps some links to files and sources) to start things off.
For now I'll give that a thought and await opinions.
