Author Topic: Can't connect to remote speakers or stereo  (Read 17342 times)
blueriver
Continued:  The stereo receiver will turn on making connection but no sound is played.
blueriver
Not sure if this is an issue:  out_apx.dll  is in Musicbee folder as well as in plugins folder??
blueriver
So, the problem is still not solved .  Would appreciate more expertise to help on this.
blueriver
I am wondering if a complete uninstall of Musicbee with Revo Uninstaller followed by a reinstall would be worth trying keeping in mind that I don't won't to screw everything up or the potential to fix the issue.  Comments or preferably help would be appreciated.
Questions:  1)  If I reinstall which version should I install and do I need to follow that install with a patch - if so which one?  2) Will I lose the remote output plugin by Eric if I run the Revo Uninstall - if I do, can I purchase it again in hopes that I can get it to work?
If I can provide any other info to help someone with more knowledge then I have figure out why I can't get remote speakers to play wirelessly, please let me know.  I have Windows 10 as operating system.
Again, a plea for help.  There must be a way to solve this issue.
Thanks to all!
blueriver
Here is the error message when trying to play remote speakers:
Ünable to start playback (error+BASS_OK)
Looks like an issue with Musicbee.
