Author Topic: no content of folders with both playlists and autoplaylists in left panel  (Read 1276 times)
HHM
in left naviagation panel i have plenty of folders containing playlists. if the folder contains only regular playlists, then clicking on folder's header show it's whole content in the main panel (so tracks from all subplaylists altogether in one view)
However it doeasn't work when folder caontains a mix of playlists and autoplaylists - clicking on the header shows no results in main panel, as if the whole folder was empty.
Working fine for me. You might have removed or misplaced the definition file (.xautopf) for the folder.
HHM
You're right, the .xautopf file must have been corrupted, I've deleted it and everything works fine. thanks for advice!
case closed :--)
