Author Topic: to use qaac do i need to setup in tools or file converters?  (Read 5728 times)
gaiastar
Hi
how can i use qaac?
should i add it in file converters or in tools?
and how can i add ?
thanks
Copy the files into Codec folder. Then configure it in file converter settings.
gaiastar
hi
but in the converter settings there is no qaac
should i delete an encoder and add for example -s --tvbr 112 --ignorelength - -o %output%
with this command it should create 255kb file
thanks
gaiastar
Here's how my settings look:
hi
i don't have it this
in short i have to drop out nero encoder
or can i edit and add more encoder list ? is there a file to edit to add more encoders?
To change the encoder, click on ... button on the right. I don't think multiple encoders are supported for a single format.
gaiastar
hi
i have always errors even if try to convert to wave
look
try changing the title tag to remove the | character
if thats the reason then its a bug that i will fix
gaiastar
Hi Steven
it's not |
it's the musicbee does not save to L\convertmusic but tried to save to C:\
and with the w10 last update , i have protected some folders , musicbee try to use i guess as temp file
tried under w7 no issues at all
thanks
gaiastar
Hi Steven
maybe you could add in the option to select a  temp folder
thanks
hi
your settings don't work ,i mean qaak
thanks
Yeah, I forgot I didn't configure for small & standard option for qaac as I don't use them (looks like they are nero settings). High, maximum & ALAC should work.
gaiastar
hi
org vorbis doesn't work ,clean install portable
Last Edit: October 26, 2017, 10:49:46 AM by gaiastar
gaiastar
I don't understand what you mean. Post a screenshot.
hi
try a clean install and use this econder
