Author Topic: setting to open program on Windows startup  (Read 3013 times)
BoosterDuck
I'm not really a fan of adding shortcuts to the startup folder, I would like to see an option in preferences
Easy to do by yourself. Create a shortcut for MusicBee.exe and then drag (move) the shortcut to start menu > programs > startup.
MB also has some command line options - you might want to search the forum or the wiki for those, if necessary.
