Author Topic: Highly critical LAME WAV Processing wChannels Sign Extension Vulnerability  (Read 3371 times)
Chris19
Hi All,
Just Installed latest MusicBee.
I use Secunia PSI as part of "keeping software up to date"
"It shows:Highly critical
Secunia Advisory SA62995
Description
A vulnerability has been discovered in LAME, which can be exploited by malicious people to compromise a user's system"
Is this correct?
 Chris.
If you have any concerns about the LAME version bundled with MusicBee then just download one from somewhere like rarewares.org
and replace the one in the codec folder
